Ke30 Auto To Manual Help
Hello to all,
I have not been very active for a while, working in another state cramps the style a bit!!
I have just spent the weekend swapping over a 4K engine and 4 speed manual from a Ke55 into a Ke30 auto.
I have everything in, except the gearbox bracket from the Ke55 does not line up at all with the old automatic bracket position in the Ke30.
Has anyone done this conversion, I assume it is common??
Do I need a manual gearbox bracket from a Ke30 or is it something that has to be made up??
Any help would be appreciated.
Cheers David
2 speed or 3 speed auto?
2speed cross member is the same as manual, but the later 3 speeder is very different!
Thanks for the reply, it is the 3 speed (trimatic) gearbox.
Hey there fella, it sounds like your one of the unfortunate guys that has a ke30 with NO BOLT HOLES for a manual crossmember? (underside of tunnel), only has the holes for the auto crossmember?,
cheers phatke30!
Edited by phatke30
cheers phatke30!
That sounds like what I have, is there any way around it, or am I stuffed???
cheers
dave
You will have to get a custom cross member made up...or get the mounts welded to the underside of your car.
thanks for the replies everyone.
Rolla Boy, where is a good place to get a custom cross member made up in Canberra???
cheers Dave.
Possibly want to try contact Gareth Paton...as far as I am aware he does back yardies...and he is an absolute genius with all things CAR
Thanks for all your help- will give him a bell.
Cheers
