7mm out of a 4k bore.....i've heard of some 4k's going out to 160 thou over......but i'm pretty sure they were a jap commerical engine.
taking 3.5mm off each side of the bore is going to greatly hamper the running of said engine i would think.
Xany you hit it on the DOT :P
The commercial 4K motor got thicker bores and can be bored out more. Mate of mine proved this. The average 4K out of your KE70 etc can't be bored as far.
I think some fork lifts did get 4K motors I know these have thicker bores.
But probably easier to get a 5K than track down a commercial 4K.
Cam
well thanks for all the info, so what pistons will fit into 4k that are a bit oversize but arent custom made, and arent 1ggte pistons, or do people think i should go bigger pistons for motorkhana/khanacross or just get some aftermarket standard bore size??
