Idleing Troubles
Hey
Until recently my little ae82 has been going great. But now it seems to be idleing irregularly. Sometimes it will idle fine and others it will jump between 500rpm and 1000rpm.
Any help will be arrpeciated.
hey man i'm far from a pro on this but i would just go and check the essentials. things that come to mind are checking the condition of your plugs, oil, filter and ensure that the intake side of things hasn't got too much buildup. i.e. in my carby model i'll use carby cleaner every few months to keep my intake as clean as possible. if the solution isn't that simple definately see if a local mechanic will take a look, most times they will be more than happy to have a look and make a recommendation at no charge. good luck with it
p.s. i think you'll get more helpful responses if you give info about what type of engine and mods you have
thanks buddy for the response
i have changed my plugs and oil and all that jazz around a week ago, no different to what i use. ive checked alot of stuff and its all good. but today it idled really well which is good but yeah.
and all I'm using is a stock 4ac engine.
but anyway we will see how it goes
thanks
sorry to steal your thread bro but i have the same thing i was just wondering where is the idle screw on the carby. i own a gemini and they are right next to eachother, but i can't find it on my rolla. i see the air fuel screw i just can't find it. please help.
cheers
Edited by dailyrollaae71
My idling screw is located on the back of my carby aye
i just put a carb kit on my carby so new gaskets and plunger and stuff
it seemed to help a bit but there is till a bit of hesitation there
might try some leads 8/
yeah put new leads on aye
helps the idling a bit better
but i have a flat spot when i put my foot down :wink:
its annoying me.
