Everything posted by benny1991
Ke70 Headlight Issues
Do I run a negative off where the rb was meant to be for them to work?
What about r/b, is that just a ground? If it is did you just make a new one?
Or would it be easier to install hid kit? Will they even work with my current issue?
Thinking I may just do the re-wire with the relays and hopefully get these damn headlights working!
So this problem fixed itself after a day now it's back, I have 12v at the relay and redone all the earths. What earths does the headlights actually use if anyone knows?
I thought it might have been but its doesn't appear to be broken on both the assembly's I got
Hey guys, As the title states I'm having trouble with my headlights. The parkers work, dash lights all work but no headlights. When you try to turn the headlights on the highbeam light comes on on the dash. The only way the headlights work is if they are in the on position and you hold the stalk back like your flashing high beam. If you try to flash the high beam in any other position the headlight relay makes a buzzing sound. I've tried changing the stalk and relays but nothings changed. All earths seem to be good...... It's really starting to annoy me as I can't drive at night. Any help would be greatly appreciated. Thanks, Ben
Starsharks?
P.s. What car were they for? Mine are sitting on my ke70.
Starsharks?
What height is your car at? Mine is just below 100mm with the same size and offset rear, and for the rear I had to flare the guards a bit. Fronts I'm unsure about as mine are 6 inch with about +6ish offset but I don't see why they wont fit easy enough.
Ke70 4K Overheating Troubles
Cap is brand new aswell, and the radiator is fairly new aswell. It seems to be flowing better then ever but yeah.
Yeah I have done all that but to no result, still overheats ergh :bash:
Hey guys, As the title states, I am having some issues with my ke70 overheating. Mainly on the highway the temp will just jump up pretty quick. Around town it usually sits around 1/3 to 1/2 on the temp guage. It is just a bog stock 4k, have replaced the water pump but with not much change in what is happening. It has a restrictor in it instead of a thermostat ( basically a gutted out thermostat), all new coolant etc. Block and radiator have been flushed and are all clean, it's just really starting to annoy me! Any help or ideas would be greatly appreciated. Cheers, Ben
Vibrations....Eek
There is still some shaking, and it is starting to annoy me! erghhhhh. As for the cable, ill have a play around tomorrow. It was all put back in the same spot and everything alligned, but once again I guess its just trial and error on things
Vibrations....Eek
There is a new spigot bearing in there now, but there still seems to be some vibrations at certain revs and still the clutch just doesnt feel like it wants to 'pop' when jolted
Vibrations....Eek
Nah used all my clutch pressure plate and flywheel as the engine had a torque convertor still attached ( fail )
Vibrations....Eek
Wouldn't it be scraping on the flywheel if it was on the wrong way?
Vibrations....Eek
Hey guys, My 4k was getting really tired so i scored a 4k off a mate to replace mine. It was removed from a ke55 and was being put into a ke70. It al went in smooth enough, but now on idle and through some revs it shakes and vibrates all the interior in my car..... I really am unsure of why. That is why I put it to you rolla club to help me out. It also seems my clutch feels different, it does not want to 'pop' when i jolt on it. Just seems to a little then takes off as normal...... Please please please help me! Any help is muchly appreciated, cheers.
Rollaclub Stickers
I'm keen on one of the Jap Style rollaclub.com stickers. Pm me with more info if possible on how to pay etc :)
Reverse Lights Problem
Well it seems to have power at the ignition and guage fuse but when I try to find any sort of power at the gearbox wire ( i hope i was trying the right ones) there is nothing there. So somewhere along the line something is gone? Is it anything to do with the gearbox itself? Its an original 5 speed.
Cam Troubles (Help Please)
Timing?
Oh woops sorry, no its actually for my 84 ke70. Sorry about that
Hey guys, so checking all my lights today and realised my reverse lights do not work. There are new bulbs in them and they are grounded correctly but it is just not happening. Is there something else I should be checking? Thanks in advance
Horn Wiring
Thanks for that man, ill give it ago tomorrow when the sun comes up :)
Horn Wiring
Ahk, yeah well thing is it didn't have anything like that when I bought the car. So I need a way around that without using said part
Horn Wiring
Hey guys, I'm trying to re-wire my horn in my 84' ke70 as the person before me didn't hook the horn up with the boss kit, so I am in need of a wiring kit to find the wire for the horn. Or even a suggestion of how to wire it to the back of the button. Any help would be appreciated
