i think my fuel pump relay shat its self is there any way to check if its that i though it was a grounded i fixed it and it worked for a while but now it doesnt and no the fuel pump is not broken just in case any one asks :drgrim:
cheers
oh and by the way its a 4age running a 2rz hiace pump if that helps
could u swap it with one you know works? quick and easy check
yeah but that costs money and during my conversion ive wasted so much money on things that i thought were broken but werent so i want to be sure that its either brokn or somethin else is screwin it up
http://www.rollaclub.com/faq/index.php?tit...ng_Relay_Wiring
You have to make sure there is resistance between the windings with a multimeter (Black & White/Black)
Then when you power the White/Black with 12v and ground the Black wire the White/Red & Blue/Black should go from an open to a closed circuit.
Also when you touch the Green wire to ground it should do the same thing.
