fozz Posted January 10, 2008 Report Share Posted January 10, 2008 i think my fuel pump relay shat its self is there any way to check if its that i though it was a grounded i fixed it and it worked for a while but now it doesnt and no the fuel pump is not broken just in case any one asks :drgrim: cheers oh and by the way its a 4age running a 2rz hiace pump if that helps Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted January 10, 2008 Report Share Posted January 10, 2008 what sort of relay is it, circuit opening relay or just a generic one? Quote Link to comment Share on other sites More sharing options...
fozz Posted January 10, 2008 Author Report Share Posted January 10, 2008 what sort of relay is it, circuit opening relay or just a generic one? circuit opening relay Quote Link to comment Share on other sites More sharing options...
Rollaboy2608 Posted January 11, 2008 Report Share Posted January 11, 2008 could u swap it with one you know works? quick and easy check Quote Link to comment Share on other sites More sharing options...
fozz Posted January 11, 2008 Author Report Share Posted January 11, 2008 could u swap it with one you know works? quick and easy check yeah but that costs money and during my conversion ive wasted so much money on things that i thought were broken but werent so i want to be sure that its either brokn or somethin else is screwin it up Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted January 11, 2008 Report Share Posted January 11, 2008 http://www.rollaclub.com/faq/index.php?tit...ng_Relay_Wiring You have to make sure there is resistance between the windings with a multimeter (Black & White/Black) Then when you power the White/Black with 12v and ground the Black wire the White/Red & Blue/Black should go from an open to a closed circuit. Also when you touch the Green wire to ground it should do the same thing. Quote Link to comment Share on other sites More sharing options...
fozz Posted January 11, 2008 Author Report Share Posted January 11, 2008 cheers man ill give it a try Quote Link to comment Share on other sites More sharing options...
