April 20, 200818 yr comment_240533 My 4k blew the head gasket so Its a good time to get the head shaved to give it a bit more power how much would you recommend taking off I'm thinking around 20 thou but tell me what you think. :dance: Report
April 20, 200818 yr comment_240536 Ten to twenty is what they'd take off in a normal sort of skim. I once had a head that was shaved .125". The screwdriver holes for lifting the head off weren't there anymore. Twenty would be fine. As would probably anything up to .060" Report
April 20, 200818 yr comment_240537 40thou sounds sweet. Snap bang in the centre of 20 and 60 thou. Make sure to clean the deck of the block aswell, so that your new gasket can sit in flush. Edited April 20, 200818 yr by harun Report
April 21, 200818 yr comment_240763 thats 3 mm - crazy. what comp were you gunning for with that Dwarf? Report
April 21, 200818 yr comment_240798 Well, it was back in the days of AvGas, thus we were looking for 11:1 plus. Can't remember what we ended up with, but it went well for a while. Report
April 21, 200818 yr comment_240827 Meh, it really just wore out. Nothing went bang as such, it just got tired after about two seasons. Report
April 23, 200818 yr comment_241330 oh well, shave it another 1mm and see what happens then hahah. Report
April 27, 200818 yr comment_242511 Meh, it really just wore out. Nothing went bang as such, it just got tired after about two seasons. Factory bottom end? Not bad. :lolcry: Report
