Rb20det Ke30
I'm in Redland Bay weird i havent seen it around.
How does the 2.7 conversion go, any times down the track???
What year is the engine??? I want to get a vvti 2.7litre
hi, i,m in beenleigh, the 3rz have some issues (they break con rods), on toymocs there's a 2rz/3rz dedicated thread that is good for info. you can come have a look if you like or check it out on rides and projects ke38 wagon, very easy fit. in modified form the vvti doesn,t make as much power as the 3rz. check out the A.R.E silvia 760rw or LC engineering up to 1600rw but without spending$$$$$$$$ 400rw is easy with huge torque figures
What model hiluxs is the 3rz in??? Also did you have to change the engine mounts?
98 TO 04 i'll explain it step by step if you want, or come have a look
Ill probably have a chat to my old man and see what he says. How much did it cost up to the point of turbo??? Just NA
