hey,
just wondering what is the difference between the 4k and 5k oil filter block thing ( the thing thats attatched to the block and then to the oil filter)
i forgot the technical name, just want to know if i can use the 5k one on the 4k, or do they run different oil pressures etc. it all bolts on, but they look different
i know alot of the 5k/4k bits are interchangable i just wasnt sure wether they had a different oil pressure due to more capacity
cheers all
chester
How does a bracket that hold the oil filter increase oil pressure!? :P
Spittao.....you really need to remove shit from ears (or eyes), and head from arse befor clicking that reply buttom each time! Don't make your reputation worse!!! :y:
Chester - Yes they are 100% interchangable between 4 & 5k's. No problems like changing oil pressure or the like, and they both take the same part number filter. :yes:
