chester_fb Posted May 20, 2008 Report Share Posted May 20, 2008 hey, just wondering what is the difference between the 4k and 5k oil filter block thing ( the thing thats attatched to the block and then to the oil filter) i forgot the technical name, just want to know if i can use the 5k one on the 4k, or do they run different oil pressures etc. it all bolts on, but they look different i know alot of the 5k/4k bits are interchangable i just wasnt sure wether they had a different oil pressure due to more capacity cheers all chester Quote Link to comment Share on other sites More sharing options...
[email protected] Posted May 20, 2008 Report Share Posted May 20, 2008 if anythin e all fit it would increas the PSI or just stay the same, give it a shot i say, might work beta. let us know. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted May 20, 2008 Report Share Posted May 20, 2008 How does a bracket that hold the oil filter increase oil pressure!? :P Spittao.....you really need to remove shit from ears (or eyes), and head from arse befor clicking that reply buttom each time! Don't make your reputation worse!!! :y: Chester - Yes they are 100% interchangable between 4 & 5k's. No problems like changing oil pressure or the like, and they both take the same part number filter. :yes: Quote Link to comment Share on other sites More sharing options...
chester_fb Posted May 20, 2008 Author Report Share Posted May 20, 2008 cheers mate, got the oil feed line all sorted for my turbo 4k now :yes: Quote Link to comment Share on other sites More sharing options...
