Can someone tell me if the front brakes on a AE 71 are the same as a KE70 especially the backing plate. Want to use them to convert an old Morris from drum brakes to discs. I know KE70 are easy to adapt.
Thanks
yes they are
unless early flat front ke70 is different to later ke70 its all the same gear.
exception is the ae71 panel van which had larger brakes (adm sprinter?)
yes they are
Spot on, all KE70's and AE71's had the same brakes except for the AE71 panel van which as said had the ADM AE86 brakes
