June 30, 200818 yr comment_257310 i've got oil on the bolts on my inlet manifold. i've no idea where it is coming from any ideas? here is a pic. its dry above the bolts. i've taken the bolts out and the threads are dry. Report
June 30, 200818 yr comment_257339 Looks like its sprayed upwards to me. Is that the oil pressure sender there? or a knock sensor? Report
June 30, 200818 yr comment_257348 That looks like a knock sensor. What motor is it? a 4AGE. Might be worth resealing any rubber gaskets nearby with some blue goo. Looks pretty minor though. Report
July 1, 200818 yr comment_257465 looks like a smallport, plug that knock sensor in too man. i know what it is i just can't explain withough showing you... Report
July 1, 200818 yr comment_257499 Pfft you call that oil. buy an old porsche and you'll learn about oil hahaha. Report
July 1, 200818 yr Author comment_257506 yep, its a smallport, and that is the knock sensor. i use a haltech e6x - no knock sensor input. so the oil is blowing up in the wind after seeping from between the block and the head? Report
