Ke70 - Ke55 Box
Guys I have a 5 speed box from a KE55, what do I need to do to the box to make it fit in my KE70? The KE70 box is longer and is only a 4 speed... ive had a look at the Knowledge Base and it mentioned that 4 & 5 speed extension housings arent interchangable to each other. Does it mean though, that I can put the 5 speed KE70 extension housing on the KE55 5 speed box and fit it into my KE70? are the front part of the boxes the same.... thanks
Edited by rolla83
ok how about a 4spd shifter onto a 5spd ke70 box?
a 4spd shifter won't without some mods
so ure saying that the front half of ke boxes are mostly the same, they just changed the extension housing on the ke70, however if you want a box from a KE55 to fit your KE70, just pull the extension housing from your KE70 box and bolt it up to the KE55 box and it will bolt up like no changeover ever happened??
yes.
exactly.
:eatlead:
only if it's a 5 spd!!!
kewl, will give it a go....
