DAROOKIE Posted September 2, 2008 Report Posted September 2, 2008 Well firt of all I am new to the rolla club. I just got a 1973 ke20 with the 3K engine and tranny. However I just picked up a 2TC motor nd 5 speed tranny includint tranny crossmember and driveline. Also got a set of 44mm mikunni sidedraft set up for a 3TC. How hard would it be to swap into my KE20 and what thinggs would I need. Great site by the way fellas. Quote
oh what a nissan feeling! Posted September 2, 2008 Report Posted September 2, 2008 Welcome to rollaclub! This conversion has been done quite few times, so have a look around with the search function, you will find it has mostly been done to a ke30/55, but same old. The gearstick hole will pretty much fit, with a tiny trim to the back edge. You will need custom gearbox and engine mounts. You will need to convert to a hydrolic clutch too, which is probably the biggest hassel. Use a ta22 clutch master cyl. Cheers Quote
DAROOKIE Posted September 4, 2008 Author Report Posted September 4, 2008 Somebody told me I could TA22 engine mounts. Does anybody know about this? What year TA22 for the clutch pump and what about the drive shaft. Welcome to rollaclub! This conversion has been done quite few times, so have a look around with the search function, you will find it has mostly been done to a ke30/55, but same old. The gearstick hole will pretty much fit, with a tiny trim to the back edge. You will need custom gearbox and engine mounts. You will need to convert to a hydrolic clutch too, which is probably the biggest hassel. Use a ta22 clutch master cyl. Cheers Quote
Redwarf Posted September 4, 2008 Report Posted September 4, 2008 Somebody also told me the moon was made out of cheese. You are going to need to move the mount on the crossmember. There's a good chance you will also need to change your swaybar to clear the sump. Go to repco and ask for a ta22 master. They should be all the same. Gear box mount should be fine if you have the bolt holes in the chassis about 6 inches further back than where it currently mounts. If you want to make it perfect, you may need to move the holes sideways a bit. I know I had to do get a tailshaft made for the 37, so I expect you'll need one for a 20. (I managed to source one already made for mine.) Quote
