A little wile ago i noticed that ocasionaly, my engine would be reving a little higher than usual when i put my foot on the clutch/ out of gear.
When i bumped the accelerator or pulled the choke on and off it went away.
It slowly got worse. So i spayed some RP7 on the springs n stuff on the carby. It seemed to work for a wile. it has now come back REALY bad. For example reving at 3500 rpm when you try and change gear.
I have have tryed above, looked for kinks or splits in the accelerator cable, and the peddle doesnt seem to be getting jamed on anything.
So i was wanting some advise on what the problem might be and how to fix it.
BTW i have a 5K with 3K carby. don't know if that helps.
Cheers
Doug
EDIT:
don't know the exact cause but i fixed it :P
took carby off, gave it a bit of a clean with air compreser n stuff. And I also replaced the vacume hose that comes off the manafold onto the brake booster as it was shit.
So somthing worked
Edited by DouggehKE30
Carby might even be in need of a rebuild
The carby was rebuilt less then 6 months ago.
But i might take the carby off and give it a good clean. So then i know its not just dust and shit.
