September 7, 200818 yr comment_273135 Hey all i found the problem with bling :D it turns out that water was getting in through no4 piston(photo attached) does anyone know if this is repairable or not and if so do they know the composition of the metal makeup as i might be able to tig weld it??????????????? :wink: Cheers rod Report
September 7, 200818 yr comment_273224 Hey all i found the problem with bling :D it turns out that water was getting in through no4 piston(photo attached) does anyone know if this is repairable or not and if so do they know the composition of the metal makeup as i might be able to tig weld it??????????????? :wink: Cheers rod I would dump it and find an other. Not worth wasting time and money on. Likely to be thin elsewhere as well. Probably a result of no or old poor glycol coolant Edited September 7, 200818 yr by tojo2 Report
September 9, 200818 yr comment_273691 That is easily repairable!!!!!!!!!! Trust me on this one! I've had to get alot worse than that repaired before. just as an example, my local engine reconditioners would charge $11 to fix/weld that corrosion and $66 for a surface regrind, hope this helps, cheers phatke30! Report
September 9, 200818 yr Author comment_273723 That is easily repairable!!!!!!!!!! Trust me on this one! I've had to get alot worse than that repaired before. just as an example, my local engine reconditioners would charge $11 to fix/weld that corrosion and $66 for a surface regrind, hope this helps, cheers phatke30! thanks for that phatke30 :y: had a chat with a few other rolla members and looks like a drive to the sunny coast is on the cards for the weekend :dance: . Report
