got one77 Posted September 7, 2008 Report Share Posted September 7, 2008 Hey all i found the problem with bling :D it turns out that water was getting in through no4 piston(photo attached) does anyone know if this is repairable or not and if so do they know the composition of the metal makeup as i might be able to tig weld it??????????????? :wink: Cheers rod Quote Link to comment Share on other sites More sharing options...
tojo2 Posted September 7, 2008 Report Share Posted September 7, 2008 (edited) Hey all i found the problem with bling :D it turns out that water was getting in through no4 piston(photo attached) does anyone know if this is repairable or not and if so do they know the composition of the metal makeup as i might be able to tig weld it??????????????? :wink: Cheers rod I would dump it and find an other. Not worth wasting time and money on. Likely to be thin elsewhere as well. Probably a result of no or old poor glycol coolant Edited September 7, 2008 by tojo2 Quote Link to comment Share on other sites More sharing options...
dashills Posted September 8, 2008 Report Share Posted September 8, 2008 hey mate thats stuffed go get one from the wreckers Quote Link to comment Share on other sites More sharing options...
Clapped out Posted September 9, 2008 Report Share Posted September 9, 2008 That is easily repairable!!!!!!!!!! Trust me on this one! I've had to get alot worse than that repaired before. just as an example, my local engine reconditioners would charge $11 to fix/weld that corrosion and $66 for a surface regrind, hope this helps, cheers phatke30! Quote Link to comment Share on other sites More sharing options...
got one77 Posted September 9, 2008 Author Report Share Posted September 9, 2008 That is easily repairable!!!!!!!!!! Trust me on this one! I've had to get alot worse than that repaired before. just as an example, my local engine reconditioners would charge $11 to fix/weld that corrosion and $66 for a surface regrind, hope this helps, cheers phatke30! thanks for that phatke30 :y: had a chat with a few other rolla members and looks like a drive to the sunny coast is on the cards for the weekend :dance: . Quote Link to comment Share on other sites More sharing options...
