October 6, 200818 yr comment_279544 Does anyone have pictures or Diagrams of mounting brackets for an sc12 or sc14 supercharger onto a 4k. preferably with sizes as well. thanks guys, Jono. Report
October 6, 200818 yr Author comment_279567 interesting, it just means I will have to find one haha. Report
October 6, 200818 yr comment_279573 Loads of KE70's have the AC gear on them, I've been thinking of setting my rolla up with AC! Report
October 7, 200818 yr comment_279833 are you going to be doing a blow through setup? what carby/fuel setup blah blah blah will you be useing? I'm thinking about superchargeing my 4k, i would turbo charge but i don't have a welder and can't weld, so supercharging would be a fair bit easier. -Alex Report
October 8, 200818 yr Author comment_279951 are you going to be doing a blow through setup? what carby/fuel setup blah blah blah will you be useing? I'm thinking about superchargeing my 4k, i would turbo charge but i don't have a welder and can't weld, so supercharging would be a fair bit easier. -Alex Twin webers with premium 96-98 RON, I'm using an ac12 blowthru, with the pipe having a welded Y intersection for each carb or I will make sum kinda custom airbox with a single pipe going to it. . it is going onto a ported manifold and ported head, lumpycam, full exhaust (2") and bored pistons....full ignition system done too.... :cool: Report
October 8, 200818 yr comment_279957 nice what cam specs? form doing a little bit of reading ive heard that with a supercharger because they create more torque its not always a good idea to have a hugely modded cam? sounds like your motor should be sweet once finished. if i ever get around to doing one it will probs just have a quick rebuild, webber, and some porting of head/manifold. maybe a reground cam, have to do more research first, still getting used to this boosting a k motor idea lol Report
October 8, 200818 yr Author comment_279970 nice what cam specs? form doing a little bit of reading ive heard that with a supercharger because they create more torque its not always a good idea to have a hugely modded cam? sounds like your motor should be sweet once finished. if i ever get around to doing one it will probs just have a quick rebuild, webber, and some porting of head/manifold. maybe a reground cam, have to do more research first, still getting used to this boosting a k motor idea lol Yeah my cam isent hugely ground, I have 2 actiuually I forget what they are that, one is sitting in my garage at mums and one is in my current 4k...I have 2 Report
