Altenator Not Charging
hey guys
i got a 4age in a e7 and my altenator is not charging i have no clue whats wrong it was working but now it stopped and my batterys completly dead and the batterys only two weeks old any help apreciated
cheers
Your alternator has a diode or two out I'd say. consdidering last time I looked at it the unit was charging, but there was no charge light coming on with ignition.
is it reparible or do i need a new alternator
Yeah, Depends how much a new diode/rectifier plate is, If that is indeed what it is. really need to split it apart and test everything before you can draw a real conclusion..
hey guys
cheers
Are the brushes on the alternator worn?
This may be a little to technical but you need to excite the alternator with a test light , checking the output Battery voltage with a Multimeter at the same time.
The charge light is not even coming on so its something a little more than brushes..
dang there not to dear to buy one from a wrecker i got one for mine for 40 bucks
and they are pretty easy to get in and out anyway
I already tested it on the vehicle, It needs to come out to be fixed...
buy a new one/2nd hand one from the wreckers.
its 2 bolts.
