October 19, 200817 yr Author comment_282637 Didnt mean it in a bad way, was meaning "good luck" in the grinding, sanding, bogging painting fun of it!! haha if you do that id say they wouldnt even notice it, I'm sure cars get panels welded in all the time, and even front sections replaced. Nar its all good, just having a giggle over it :) Cleaned out some of the bog and crap today and welded up some of the low spots, burnt through in two spots but other then that it looks better plus a bit less bog would be used Report
October 19, 200817 yr comment_282661 That might be NSW, but i know as of june or july this year the inspection rules have changed in Tassy. They actually have to hoist the car up and manually check brakes, suspension components ect. Only reason i know is i went to the place that will be doing my inspection and ask what they check, whats legal and whats not ect.. Towe, Just grind it smooth, thing layer of bog, sand, and then put deadener over it... good luck :) we hoist the car up and have a look manually at brakes suspension components etc at work, but the limits they give you...... i replace things long before they are a rego fail... stupid how it varies from state to state. what the eye don't see the heart don't grieve over, if you do a neat job of it they won't even notice its there. probably the only time someone would notice is if you took it in for suspension/wheel alignment problems and it was dodgy... you'll be fine. Report
