October 20, 200818 yr comment_282939 Hi Guys, I've got a pair of RS2000 Escort Buckets, in my KE55, obviously they have rails to suit because its a direct boltin, just checking, will these rails bolt upto my KE35 without modding anything? Thanks, :yes: Report
October 21, 200818 yr comment_283364 KE35 and KE55 same thing. Both seat rails are the same from each other as far as I am concerned. KE55 seat rails are the same as KE35 seat rails. Report
October 21, 200818 yr comment_283371 The rails are the same from the floor mounting perspective but as I found out today the part the mounts to the seat differs. Report
October 21, 200818 yr comment_283524 from what i've done over the last 12 months: bought ke30 2dr sedan seats, installed in a ke55 hardtop using the ke30 2dr sedan rails. bought early ke70 seats, wouldn't bolt to the ke30/55 4dr sedan rails. installed into a ke20 using ke20 rails. if your ke55 is a hardtop, then they will bolt straight into the ke35, as the mounts are the same. if your ke55 is a sedan, then they will not bolt in directly to the ke35. cheers dF Report
October 22, 200818 yr comment_283597 The rails are the same from the floor mounting perspective but as I found out today the part the mounts to the seat differs. ....and wouldn't that be bacause 2 door or coupe seats need to flip forward to get access to the back seat!! :laff: Report
October 23, 200817 yr comment_283978 No, I had early KE30 seats and late KE30 seats. The car in question is my panel van and the early seats that I got didn't come with rails. So I was hoping just to reuse the old ones. The under side of the seats are different. Report
October 24, 200817 yr Author comment_284125 dfunkt, wrong. haha. Just pulled them out and they bolted straight into the KE35, the backs a tiny bit harder to get into but not impossible :lolcry: Report
