March 22, 200521 yr comment_36363 i'm planning my AE71 - 4AGE project what version of the 4AGE will i need? from what car? i'm planning on buying a complete AE71 with 5 speed, and just dropping the new motor in. any ideas? Report
March 22, 200521 yr comment_36368 all depends on your budget, future intentions & mechanical ability.. Report
March 22, 200521 yr Author comment_36369 ok, ok, ok... play nicely. i've asked on toymods, and i've done the google seach, and its all confusing. i'm building a drifter. nothing special, so are the 100KW RWD AGE's easily available? expensive? and whats the description of them? silvertops? from a AE*** ???? i seriously have no idea, just thought some1 on here would have a quick answer for me :D Report
March 22, 200521 yr Author comment_36373 ok... so a 100Kw is a FWD engine, and needs to be converted to suit RWD... now quicky for a noob like me, that means that: manifold needs to be changed.. any thing else thats going to piss me off? Report
March 22, 200521 yr Author comment_36383 soo... custom exhaust engine mounts? doesnt the AGE bolt straight into the 4AC engine mounts? Report
March 22, 200521 yr comment_36386 You will also need to run an external thermostat, you will need to look at upgrading your fuel system, fuel pumps / surge tank etc. RWD intake manifold, Custom accelerator cable, engine mounts from the 4A-C can be used, also the sandwich plate between the 4A-C engine and gearbox, spigot bearing for crank, diff upgrade if you want to "drift" it.. and yes, for a N/A application, the 100KW 4AGE is good, being a 7 rib block its a very strong engine. I'm sure i've missed lots of things, its all dependant on your application, so this is very generalised.. Report
March 22, 200521 yr comment_36393 silver top 20 Valve cheapish and awesome engines. and stronger than blacktops. turbo later on down track = good! Report
March 23, 200521 yr comment_36518 Did you want that in 5 Rib? theres no such thing, you can have a 3 rib or 7 rib block and thats all there is between all 4A variant short engines Report
