ira11y
Everything posted by ira11y
  1. needless to say I wont be attending anymore cruises :P
  2. iroken, is the r32 LSD in your TA22?? as in its in the T series diff?? please explain :P
  3. occasionally :P but its not exactly a prolific forum here
  4. ira11y replied to MISS SX's topic in NSW / Sydney
    how about kiaora then?
  5. ira11y replied to MISS SX's topic in NSW / Sydney
    aloha
  6. theres no such thing, you can have a 3 rib or 7 rib block and thats all there is between all 4A variant short engines
  7. Here you go, doesent get much easier than this
  8. ok first off the ignitor medicineman is showing you have does not appear to be from a 4AGE so theres your first problem. The plug below is not used for the ecu, it looks like a stereo plug, the plug you are missing from the ecu in that shot is for the fuel pump relay which has a yellow plug. in fact the whole loom appears to be wrong, the orange plug is definately ODD they should ALL be yellow plugs like the RHS plug on the ECU. If i get motivated ill take a shot of a full loom and a coil and igniter sometime in the near future.
  9. Well you have there a big port ignitor and coil, the green plug should plug up to another green plug and the yellow plug goes to the distributor ( 3 pin), where did you get the loom for your engine? and you need to find what engine you have exactly. If your loom has grey plugs then id say that you have a smallport loom. Is that a rwd jap engine?? the dizzy looks to be a rwd version?
  10. Yahoo!!!! looked like fun, some nice smooth driving on the best run :P shame it sorta bogged down a little in the corner you first spun on otherwise itd be under the 60s mark!
  11. it will bolt straight in, steering racks are the same
