November 29, 200817 yr comment_293717 Hi Guys I have a computer & loom that is set up with coil packs for a silver top 20 valve and was wondering if anyone knew how that worked? I haven't actually got the 20v engine itself yet just all the wiring n stuff, but i just wanted to get all the info before i set it up Do i use the 4agze CAS in place of the dizzy or do i have to modify the dizzy or what's the go Thanks in advance for your help Cheers - Andrew :no2: Report
November 29, 200817 yr comment_293739 are you going to turbo the 20valve now? or is this for the te72? turbo 16v > 20valve NA anyday! Report
November 29, 200817 yr Author comment_293872 are you going to turbo the 20valve now? or is this for the te72? turbo 16v > 20valve NA anyday! This is for another project that i am toying with :no2: Report
December 2, 200817 yr comment_294715 dizzy on the 20v is at the back of the head (in rwd position) and at the side on a 16v so the gze cas wont fit me thinks (never tried) because of the angle. have seen evo coils and cas used tho. could just mode the sprocket on the end of the gze cas. you could also mod the 20v dizzy to act as a cas Edited December 2, 200817 yr by original Report
December 12, 200817 yr comment_297274 20V dizzy is a 24 - 1 wheel, with 2 home pickups, makes the same signal as a GZE cas. No need to mod it. Report
