Ignitor Wirng On 4k With Elec Dizzy?
ok recieved this in the mail today
its a bosch ignitor 9 222 067 021
it has 4 prongs, one with 3 above it one with 7 above it and one with 15 above it and one with 16 above it
where do i connect these prongs too, is it 2 to dizzy and 2 to coil, if so which prongs go where?
edit - found it
http://www.austarion.com/tech/BoschIgnitio...eConversion.pdf
so if you need it that will tell you.
2nd edit - actually, so does 3 go to neg side of dizzy and 7 go to pos, then 15 goes to pos side of coil and 16 goes to neg?
and how do i know which side of dizzy is pos or neg? as it doesnt say? just has 2 wires coming out of it
and where do i put the 2 vacuum spots on the dizzy as original dizzy only has one vacuum spot.
3rd - i did it today, used the 4ac wiring diagram in the faq
but now the tacho jumps everywhere under 3000 rpm?
how can i fix that?
Cheers.
Trav
Edited by Xany
New tacho time :)
haha, its not the tacho, i have a feeling its cause i took off the ballast resistor so its giving it 12v continusely to tach, then when you go over 3000 your giving it more electricity than what it gets at idle kinda thing so it works
but yea, trev said theres a variable resistor i can get for em, just have to find out where
cheers
Travis
ballast resistor or not, shouldnt affect the tacho. I had the same tacho on a hilux 22r motor (electronic ignition, no ballast) KE25 (points, ballast resistor) my WB One Tonner (HEI, no ballast resistor) and for a short time my ke30 (points, ballast resistor). I have a feeling theres something not right with the signal its getting.
yea true, its weird aye it works over 3000 rpm but jumpy under
trev reccons i need a variable resistor on just the tacho wire
hope i can get it working, if not ill get a nice monsta white dial one.../even though my current one has custom dials already....
trav, do you know how to use the edit button? 4 posts in a row is *** ridiculous.
I don't want to see 4 posts in a row from you again....you should know better. Consider this a friendly warning.
Edited by Xany
sorry man, didnt even realise, will edit next time for sure :)
