Toyota Sera 1990-1994
Model Code EXY10
Track 55.3" front and rear
Wheelbase
90.6"
Length 152.0"
Width
65.0"
Height 49.8"
Weight 2075 lbs
Engine Code 5E-FHE
Engine type transverse inline 4 cylinder, DOHC, 16v, cast iron block, alloy cylinder head, belt driven, with geared camshafts.
Peak power 108bhp @ 6400 rpm
Peak torque 97 lb ft @ 5200 rpm
Bore x Stroke, mm 73.9mm x 87.1mm (2.91" x 3.43")
Capacity 1496cc
Compression Ratio 9.8:1
Ignition Breakerless, Electronic igntion.
Fuel Supply Fuel injected
Steering Rack and Pinion, power assisted
Brakes Vented discs (front), drums at rear unless fitted with ABS - discs all round
Front Suspension MacPherson struts with lower control arms and anti-roll bar
Rear Suspension Trailing arm beam axle, Panhard Rod, coil springs, dampers and anti-roll bar
Wheels / Tyres
Body Monocoque construction, steel
Transmission 5 speed manual or 4 speed automatic driving front wheels via unequal length driveshafts
Factory Colours:
Greenish Yellow Mica (569)
Light Blue Mica (8G6)
Medium Blue Mica (8H7)
Light Turquoise Mica (743)
Turquoise (746)
Wine Red Mica (3J8)
Burnt Orange Mica (3K6)
Poppy Red (3E6) Wine Red MicaBurnt Orange MicaPoppy Red
Light Silver Opal (189)
Dark Grey Mica (188)
Astral Black (202) Light Silver OpalDark Grey MicaAstral Black
AMLUX VERSION
Dark Green Mica (6M1) with
Genteel Green two toning (22W) and Nimbus Grey wheels (182)
Certain colours phased out and other colours phased in during the lifespan of the Sera. Wine Red and Dark Grey for example was phased out when the phase 2 Sera was introduced, and at that point Burnt Orange and Astral Black was introduced.
Some people have had their Seras repainted - the above are the standard Toyota colours. I have seen yellow and white Seras...
Options From Factory and Costs
Sera stripe kit
runs along sills just above bottom of the door with Sera logo on door ¥ 20,000
Rear stripe kit
pair of stripes from rear of door handle to rear of car ¥ 11,000
Rubbing strip
rubber strip which runs around bumpers and along sides ¥ 28,000
Roof Blinds ¥ 14,000
Rubbing Strip ¥ 5,000
Sill strip, Sera logo ¥ 7,800
Roof tinting ¥ 19,000
Locking wheel nuts ¥ 6,000
Spoiler
smoked black perspex spoiler which goes at top of rear hatch ¥ 60,000
Sera stickers ¥ 3,000
Alloy wheels, silver or graphite finish ¥ 122,000
A number of different hi-fi head units
Â¥ 53,000 -
Â¥ 65,000
CD autochanger - 6 or 12 disc choice ¥ 51,000
Leather gear lever knob (for Auto transmission) ¥ 3,500
Leather steering wheel ¥ 6,300
Sera Keyring & blank key, gold finish ¥ 6,400
Handy Key set - plastic credit card key, keep in wallet for emergency ¥ 2,500
Central seat cubby ¥ 11,000
"Naviboy" - Electronic Compass ¥ 27,000
Dash mounted Cup holder ¥ 8,500
Special "snazzy" trim (black with colourful zigzags) - carpets and/or seats ¥ 4,000
Seat covers - black or blue ¥ 9,800
Mobile Phone ¥ 72,000
Mobile Facsimile, choice of two ¥ 242,000
Door marker lamp (rather than reflector as standard) ¥8,200
Illuminated ignition lock - small green light that st
ays on for approx 15 seconds after the door is closed. ¥6,100
Map reading light - magnetic with flexible shaft with two focus settings ¥8,800
Sera top half car cover ¥ 7,000
Rain sensor for automatic wiper option ¥ 22,000
Parking Aids, front and rear ¥ 27,000
First Aid Kits ¥ 8,000
Cool Bag ¥18,000
Ski Rack - each rack takes one pair of skis. Both doors can open independently.
Â¥ 40,000
Front Fog Lamps ¥ 24,000
Illuminated front corner stalks ¥ 8,300
Fragrancer ¥ 15,000
Air Purifier - Roof Mounted "Clean Ace" with lamp
Air is drawn in through the front, passed through a filter and out the back.
Has two controls (auto/manual) and (low/hi) and also built in interior lamp (two bulbs) ¥ 27,500
Dash mounted (single DIN) goes below single DIN hi-fi "Air Fantasy" Choice of three fragrances. Quite rare to see this. ¥ 32,000
I am sure there is more, and I can do a write up of all the problems that generally occur over the years of use.... too much for now :D
yeah that too lol :dance:
Most common things that go wrong:
Ashtray clips break - can buy these from UK
Door handle surrounds crack due to age - Toyota Dealer Item Only
Headlights dirty - Bake them in the oven minus the bulbs and all steel parts, pry them apart with a screwdriver once the silicon has melted, and clean away. Also you can fit a HID kit for $400AUD.
Clips on doors break often due to pulling the door down all the time, these are at any hardware shop.
Gas struts for doors sagging - new struts from toyota, second hand struts from some wreckers (sydney has 2 with a sera each, brisbane has none), or from Omicron in the UK. You also have balancers inside the door, these are extremely expensive to fix.
Think thats about it.
Oh and they run ONLY on shell optimax mMMMKKAY? None of this woolworths sh*t...
:D
ken streeter also does a really decent looking front spoiler and rear wing kit for these cars
A girl in our club has one of these, very cool little cars. Been passenger in hers a few times whilst having a few rum beverages and if i hadn't baught my GP i woulda bought a sera. There's was one for sale in a car yard up here at the same time (4 years ago). :thumbsup:
Got any kerb weight and/or acceleration figures? It's just I was driving the other half's Starlet on Sunday and it got me thinking about 5E-FE/5E-FHE engine swap, so I'm wondering if the Starlet would be lighter than a Sera or not. I know it's far lighter than the Paseo.
Starlet - 834kg, 55kW
Paseo - 924kg, 69/74kW (depends on version)
Sera - ???kg 82kW
Edited by ancullen
Would be the ideal, yes. But too much effort to get registered. I know that the E-series of motors has no chance for outright power against the A-series (the lack of a G-head option is a big letdown), but I think it could be plenty powerful enough.
Of course, I have read of a guy putting a 3S-GTE into an EP82 Starlet. CRAZY!!! :thumbsup: He had to get custom driveshafts made up as he kept destroying the stock ones.
My plan would be for a standard Australian Starlet (EP95R) with a 5E-FHE engine (disguised as a 4E-FE), with some performance mods (high compression, exhaust, possibly cams, etc), using the Starlet transmission with Paseo final drive and Echo 4th & 5th gear ratios (Echo, Paseo, Starlet, and some/most FWD Corollas use the same transmission). It wouldn't be a quarter mile beast, but would be AWESOME for motorkhanas (specifically the Rejex Rally).
The girl that owns it up here keeps saying she wants the 4AGZE in hers but she needs to stop spending on clothes (the girl thing) to do it.
The 4A engine swap seems like a fair bit of trouble to go to for only a moderate gain. I know that more power can be made all up with a 4A engine over any from the E-family, but surely a 5E-FTE (5E/3E-FTE hybrid) could make some serious enough power with a bigger turbo. Plenty enough for a FWD car anyway.
  • 5 years later...
Hey, i know this is an old post, I'm looking for toyota sera spare parts in sydney.. or at least places that sell them, i need headlight clips for my front left headlight as they broke in an accident (everything else is fixed I'm just down the clips)
If anyone could help me i'd appreciate it. thank you :)
