Ke70 Struts And Brakes Into Ke38
Do Ke70 struts bolt straight into a KE38 (KE55) without any modification?
I'm after a definant answer before i go out and get some.
At the moment i have Coilovers with R31 brakes and I'm not really a fan of the ride height and the hardness so i want to go back to standard type struts.
Also i have 13 inch mags that i want to run so need smaller brakes (yeah i know it sounds strange)
Cheers for all your help in advance
Matthew
Ke70 struts are shorter
I wouldn't really bother unless its a case of have to
The calipers are more or less the same - they can be swapped.
So are the rotors
same with the wheel bearings
ke70 shocks are shorter then the ke55/ke3x - but as from Monroe sizing their both a T1 or approx 39mm wide
ke70 springs are narrower - but i don't remember if their shorter as well
the top hat has to be swapped over to the ke55/ke3x one - the bolts on the ke70 top hat are in a different location.
I think you'd be better off hunting down either t18 or ae86 struts cause of their bigger diameter tubing (51mm or so, instead of 48mm) giving a bigger range of shocks
