February 11, 200917 yr comment_317264 i was looking for an ae86 strut brace to get an idea of how much they cost on the internet, and i found a place that said an ae86 strut brace would also fit into a r33 skyline... so i had a look at r33 strut braces and they look fairly similar (size wise) but seemed had a different bolt pattern... using no logic at all i came to the conclusion that if the holes were re-drilled, a r33 sway bar might fit a ke70 anyone know if an r33 strut brace will fit? and also, anyone know what strut brace will fit the rear? cheers, lance Report
February 11, 200917 yr comment_317278 ae86 strut braces fit from what i have read here, on ke70.com and ae86drivingclub have a good read through peoples project threads and find a strut brace you like the look of, find out where they got it and buy one no strut braces for the rear of keto's, have a look in your boot at your rear strut towers and you should realise why, although you could have a brace custom made for you, maybe. Report
February 12, 200917 yr comment_317628 Do you really think you'll need a strut brace for the rear, they should be plenty stiff through there with the parcel shelf steel etc. Report
February 13, 200917 yr Author comment_317929 i found someone's ride that was running a supra front strut brace but i can't remember what type of supra or where i found it :dance::,( Report
February 13, 200917 yr comment_317962 Cusco AE86 strut brace. Fits on KE70 perfect. Just make sure its a Adjustable one or it wont fit as the AE is wider. Report
February 14, 200917 yr comment_318145 just use a ae86 strut brace but don't get the flat type cusco they wont fit 99% of ae86 parts will fit a ke70 and rear one use a cusco rear strut brace Report
