turtle Posted February 26, 2009 Report Posted February 26, 2009 G,day new to the rollaclub, Just a enquiry i recently came to the problem of wheel choices for my ke20 and having the older 110 pcd less wheels available. The 114 theres heaps of variety so the equiry is as i use an newer say ke55 for the front wheels just change the front discs. The issue with the rear drums? Do i get like a back axle off a 30 or 55 70 model and use that? woulod that work or be wider or is there simply an easy walkthrough or something? cheers Paul Quote
smitty1 Posted February 26, 2009 Report Posted February 26, 2009 G,day new to the rollaclub, Just a enquiry i recently came to the problem of wheel choices for my ke20 and having the older 110 pcd less wheels available. The 114 theres heaps of variety so the equiry is as i use an newer say ke55 for the front wheels just change the front discs. The issue with the rear drums? Do i get like a back axle off a 30 or 55 70 model and use that? woulod that work or be wider or is there simply an easy walkthrough or something? cheers Paul From what I understand, you need the axles and drums from a ke30 and you need to shorten the splines by about 5mm to get the length right. Cheers, Ian Quote
Taz_Rx Posted February 26, 2009 Report Posted February 26, 2009 I have some spacer/stud changer plates on my mazda which convert from 110 to 114. They're 25mm thick so the also change the required offset from RWD to that of a FWD. I had them locally made but check with some wheel shop, you should be able to get a full set for around $300. Quote
Ella Posted February 28, 2009 Report Posted February 28, 2009 if you can use them mate i have a pair of front brakes ill sell you , everythings there caliper, disc and hubs too if you need them, all from a KE70. dunno if this bolts into your front end, also have the rest of the complete strut if thats needed. if you can use it and wish to purchase let me know mate, I'm up in redcliffe but wish to do a roadie down to GC once my rollas got rego (probably friday next week) so can probably organise delivery... Quote
