April 4, 200917 yr comment_334157 Hi everyone, I was wondering if anyone has a problem with their high beams on a KE70. If so what did u do to fix it as i have the same problem. thanks Scott Report
April 4, 200917 yr comment_334170 what problem are you having? need description for people to help Report
April 4, 200917 yr comment_334185 A problem I've had is the high beam either not working at all or just suddenly going out. The switches can be fiddled with but its probably safer to replace it. Report
April 5, 200917 yr comment_334228 best way to find out,take your car to the auto electrician and get them to check what is the cause of this problem? if you have electrical knowledge have a go! Report
April 5, 200917 yr Author comment_334281 the problem is that the normal beam comes on but when i flip back the high beam doesnt any solutions? Report
April 6, 200917 yr comment_334440 there isnt much to it mate, but it is going to require you to have a go youreslf.... also next time you ask a Q, provide as much information as possible..... starting with: when the problem started, how it started, things you have tried to fix it, extra info that might be of importance etc. initially check your high beam relay, will be located in the engine bay fuse box. there will prolly be a fuse somewhere as well, so look for that if they are ok, time to dig deaper. take off the plastic cover things around your steering column out of the end of the indicator stalk there is 3 wires, these wires control the head lights. they are very small thin wires and they will most likey be perished. on my car all 3 of these wires perished and none of my headlights worked, i replaced these wires and have worked perfectly since. good luck! Report
April 6, 200917 yr Author comment_334603 basicly i bought the car in april 08 and the first time i switched the high beam on it worked then when we got it home i tried it again and it failed. ive replaced the light relay(s) in the engine compartment and in the kick panel. when they don't switch on, i voltage tested it and all terminals were all +. ive pulled the steering wheel off and got hold of the switch and nothing seems to be melted. ive also tried to clean the contacts with a scarror but it still fails. any ideas? Report
