I need to swap a pinion flange on a BW 68 Diff. I have some concerns about upsetting pre-loads when I re-torque the nut. Any advice on the procedure would be appreciated.
Ha
according to what i have ,you mark the pinion shaft ,nut and flange with a centre punch before you undo them.
Then do them back up to line up ,NO further.NO less.
Specs ,pinion bearing preload ; new bearings with seal 1.7Nm-3.4Nm
;used bearings with seal 1.7Nm-2.8Nm
NB if collapsible spacer is used for a second time a 0.76mm shim must be used
This according to mr gregorys manual hope this helps
rob
