like everything else good on yahoo jp auctions,
Seller will not ship internationally
but LOOK AT THE SIZE OF THE PORTS!!! my god you could lose a kitten in them!
it basically says
it's an old 4k head from back in the days of TRD. it has twin valve springs, bronze valve guides, 7mm valve stems and berillyum valve seats. apparently this head could make 170ps on the trd stage 3 motor. i don't know how true that is, but if you don't know how to build the rest of the motor, don't buy the head. no guarantees it's a good working head, no refunds given. the valves are aftermarket, inlet 39mm, exhaust 32mm
the auction hasn't reached reserve yet. it's had a relisting.
Edited by Super Jamie
that looks like a 5k head, notice the water jacket around the chamber, i didn't think 3k-4k heads were that big,and also the head gasket marks, between the cylinders, they look too close together.
interesting point. keep in mind it was probably hooked up to a massively oversize trd 4k in a starlet, and hence using massively oversize head gasket
i did notice the shallow combustion chamber though, i would assume it's a 4k-e or 4k-u head, which would be likely, given its' japanese past
