Hi.
I have some shocks/struts on my garage, and i want to find out if i can put AE86 springs on my KE70 1979 with the struts of the TE71 SR5.
The diameter of the spring plate on the KE70 is around 14.5, and on the TE71 16.5.
AS well, the outter diameter of the strut (where we put the shock in right?) is 5.5 on the TE71.
SO maybe i can use springs and shocks of the AE86 ?
Thanks a lot
can anyone mesure pleeeeeaaasse :P
The spring diameter for the AE86 is 140mm lower and tapers in to 112mm at the top of the spring.
Strut outer diameter is 50mm.
Hope this helps.
