hi everyone after counselling with people everyone is saying that i have broken the input shaft
as well as the clutch
the car starts in gear no clutch doesnt stall and i can change gears with out clutch
but the gears don't engage
it just sounds like freespin
i was wondering how much and what do i have to do to fix the first problem thanks
input shaft maybe but it sounds like its only a clutch to me.
your pressure plate could have collapsed?thats why you can start in gear and no movement on the car?
If you're not hearing grinding noises (pressure plate etc flopping around inside the carrier), then it's more likely you've done the input shaft.
There's no escaping it ... you're going to have to pull the transmission out and have a look.
cost? Can't tell until we know what the damage is. You could be up for new flywheel, clutch, input shaft, bearings etc etc ...
cheers,
Slapper
Have you checked to see if the tailshaft is rotating also?
Long shot but you could have also blow the spider gears out of the diff!!! :lol:
That's a point ... you might have just broken an axle even ...
but it starts in gear without clutch and doesnt move or stall
and also you can change gears without the clutch
but i do not smell any clutch it is a mechanical clutch tho
It will still start in gear and not move if you have a broken axle.
I suggest starting it in neutral, looking underneath it while someone lets the clutch out. If the tailshaft is spinning it is not your gearbox and it will be something diff related.
