4age Problem
hey
i have a problem with my 4age in my 93 rolla idling when the AC is on she idles at about 600-1000 when ac is on and is unstable, she doesnt just sit on 1k or 600 she moves all over the place!!!!
does any one know how i can fix this?
my 4age uses too much fuel she goes through pretty much a full tank in little over 150ks and i have only a pod in the car, can anyone help on this?
What is your idle like when the air-con is off?
(Note I'm assuming you've got a smallport 16v 4AGE)
When you turn the air-con on, there should be an idle-up valve that opens to let an extra amount of air past the throttle body to take into account the extra load of the air-con compressor - this valve could be sticking or otherwise not functional
As for the fuel consumption, how many litres are you going through (also assuming fuel gauge is accurate)? Do you blow excessive amounts of black smoke when driving? Does the car feel sluggish or otherwise under-powered? Are the spark plugs fouled? Is your oxygen sensor reading correctly? As you have a pod, are there sensors or valves which have been removed from the intake?
Best thing to do is get your hands on a 4AGE diagnostics manual, do a diagnostics check on the car (bypassing the TE1 and E1 pins in the diagnostics plug with a paper-clip and then counting the flashes of the Check Engine Light on the dashboard) and see what that tells you first.
Edited by Hiro Protagonist
ok cheers
50ltrs and the car has more pwer, no black smoke, sparks are fine and nothin has been removed just the old filter, i don't know about the oxy sensor
ok cheers
If you're using 50L in 150km (thats over 30L/100km), it has to be going SOMEWHERE. If it is being burnt, then you'd notice a _lot_ of black smoke (rear bumper would probably be covered in soot too). AFRs would be stupidly rich, too.
Check the O2 sensor, even get it dynoed to see power and AFRs. If they are fine, and the O2 sensor is fine, then about the only think I can think of is that it is leaking somewhere, or evaporating somehow.
not sure if the original filter had a temp sensor bu ill check soon, nd nothin is leaking, and ill check everythin tonight
Did it have an air temp sensor in the original filter housing? Is it still hooked up after the change to the pod filter?
Doubt just the air-temp sensor alone would cause that drastic fuel consumption, for a long time I was running the AE82 TC without an air-temp sensor at all and it's fuel consumption was only around 8L/100km. AFRs were rich on the dyno, but only around 11:1.
Fair enough. What about the water temp sensor? The ecu could possibly think the motor is cold and be running full cold fuel enrichment.
As stated earlier, you should run a diagnostics check on the ecu. Then maybe with the help of a manual, and a multimeter start testing sensors.
Could be, would be pissing black smoke though. Although cold-start only adds the extra cold-start injector, not more fuel from the main 4.
so ive fixed the idle but I'm not sure on whats going on with the fuel consumption yet
lack of water temp sensor and/or air temp sensor wouldnt cause those kinds of fuel consumption numbers.
You have a fuel leak.... its that simple.
Check the ENTIRE fuel system.... its coming out somewhere!
