El corona Posted May 29, 2009 Report Posted May 29, 2009 just put the head back on my 4k after getting it face and all that. after putting everything back on tourqe down properly the car will turn over. there is spark and fuel but just wont run. what can be the problem? Quote
beerhead Posted May 29, 2009 Report Posted May 29, 2009 Did you put marks on your dizzy so that if could be put back in properly? Quote
trav_555 Posted May 29, 2009 Report Posted May 29, 2009 Guessing no... Your gonna need to take dizzy out put it to TDC and fit the dizzy correctly, someone will explain how, i can't be bothered Get a workshop manual Travis Quote
Budowski Posted May 29, 2009 Report Posted May 29, 2009 just put the head back on my 4k after getting it face and all that. after putting everything back on tourqe down properly the car will turn over. there is spark and fuel but just wont run. what can be the problem? "face and all that" ? so have you had a full head recon or just the surface faced ? why i ask is have you adjusted the valve clearances so they arent staying open when they are supposed to be closed ? Quote
El corona Posted May 29, 2009 Author Report Posted May 29, 2009 yea, i got the head faced, getting mat to check the vavle clrearence today for me Quote
love ke70 Posted May 30, 2009 Report Posted May 30, 2009 check valve clearances. did you remove the distributors? I'm assuming you did, but along time since i played with a K motor, if you did, get a workshop manual and re-install it as per their directions, theres about 24 teeth on them, and only 1 way is right :rolla: Quote
El corona Posted May 30, 2009 Author Report Posted May 30, 2009 check valve clearances.did you remove the distributors? I'm assuming you did, but along time since i played with a K motor, if you did, get a workshop manual and re-install it as per their directions, theres about 24 teeth on them, and only 1 way is right :rolla: nope left the distrubutor on Quote
philbey Posted May 30, 2009 Report Posted May 30, 2009 Does it fire at all? or does it just turn over w and over and over.....? Quote
Felix Posted May 30, 2009 Report Posted May 30, 2009 (edited) As others have said check the valve clearances. If you've had say 1mm skimmed off the head and the clearances are supposed to be say 0.2-0.3mm then the valves won't be closing. Edited May 30, 2009 by Felix Quote
