RainWarriorDregs Posted June 8, 2009 Report Share Posted June 8, 2009 Hey guys, i've searched around and i can't find an answer to my question. I've just recently started changing my slanty face ke70 to a flat face one so in the future i can do the quad healight setup. Why i went about it in the hardest possible manner don't ask, ahah. Anyway, i've refurbished all my parts and stuff and fabricated some brackets to hold the lights in. However my problem is that the indicator wiring is different. The slant face has two positive and one negative because of the two bulbs in the indicator housing but the flat face indicator only has one positive and one negative. I'm not sure what to do. If i don't return the current from that extra wire the fuses are going to thihnk its blown all the time won't they? Or is it as simple as twisting the two positives together?' i'm stuck! help Cheers Dregs Quote Link to comment Share on other sites More sharing options...
trav_555 Posted June 8, 2009 Report Share Posted June 8, 2009 This might help you ;) Travis. Quote Link to comment Share on other sites More sharing options...
Grifty Posted June 8, 2009 Report Share Posted June 8, 2009 twist the two positives together and you should be good to go. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted June 9, 2009 Report Share Posted June 9, 2009 Slant front has park light and indicator, Flat front only has park light.. So that is the difference, Cross those two and you will have indicators going on park lights and park lights going on indicators.. Quote Link to comment Share on other sites More sharing options...
love ke70 Posted June 9, 2009 Report Share Posted June 9, 2009 what medicine man said, work out which one is for indicators and which one for park light. hook the park light up and insulate the indicator one, and you should be fine ;) Quote Link to comment Share on other sites More sharing options...
RainWarriorDregs Posted June 22, 2009 Author Report Share Posted June 22, 2009 i did at ^^^^^^ and it worked a treat, thanks guys!!! problem solved Quote Link to comment Share on other sites More sharing options...
love ke70 Posted June 23, 2009 Report Share Posted June 23, 2009 glad it all worked out for ya mate :) Quote Link to comment Share on other sites More sharing options...
