3k Engine Bottom End
i have just got a s/hand engine ..i have the sump off, how much movement should there be in the big ends ....i can wiggle the caps (with a baby rattle some more than others) i was told this was a runner but not 100%
how much is too much ?
has anyone got info on bottom ends ?
a little movement front to back is normal but if you can move them 90 deg to the crank it's time to start measuring for a rebuild.
Undo the big end caps and check the jounals and bearing shells for wear. If good you can retorque them. Better still plastigage them.
As stated a bit of end play is normal, measure it with a feeler gauge. You should not be able to detect side to side play.
Edited by Felix
