CALE12
  1. there is one out there !! and can be used for are rules, have checked with DEZ on that i have one but is looking for one more !!!
  2. NO you can't ! ,but you can't take one out if its already not there ! :P
  3. the best one i am looking for is a mech-carby but with-out the air butter fly(swinger) above the base of the secondary ..i have one ! but would like one more !!!!!
  4. if theres any 3k carby masters out there please drop a line .........i am looking for the best carby to use on a 3k engine we must use oe carbys ....she normal in use around 2500-8000 rpm any ideas ???
  5. i thought there was only one size ports ????are they like the 3k head with 5 sizes
  6. oh ! looking for ones about 165mm for a bitza 3k with 5k head for the road car
  7. cheers for your help......is there much differance
  8. ???????????????????????????
  9. does anyone know the length of the 5k push rods vs the 3k rods
  10. its from 3,000 -7,800 abut not for long
  11. need input ....the small port give more low end power but flat lines at high revs and big port high end power but lower bottom end speed !! this is for a 3k engine only running 2nd gear...2,000 rpm to 7,800 i know it all about the cam range but want from anyone ???
  12. check your tail shaft rear control/trailing arm bushes if ya can't find anything take it to a tyre shop like beaurepaires, they can do some of the trouble shooting for ya
  13. my 3k engine turns over but the lifters are not moving(IE valves)i am thinking brocken timing chain ...at first i thought it was a brocken crank ! but it works on the front pulleys and went you trun the engine over it has heeps of blow back through the air filter,i took the tappet cover off but when she turns over there is NO moving parts up top.... any other things i need to look at before pulling here out
  14. i have just got a s/hand engine ..i have the sump off, how much movement should there be in the big ends ....i can wiggle the caps (with a baby rattle some more than others) i was told this was a runner but not 100% how much is too much ? has anyone got info on bottom ends ?
  15. i have mine blocked off..but if your fuel tank has a AIR TIGHT seal the pressure build up will push fuel through the carbie and down into the engine oil .....just went through that ! it took me a month and x3 fuel pumps x2 carbie kits to work that out..... just a thought
