i have just got a s/hand engine ..i have the sump off, how much movement should there be in the big ends ....i can wiggle the caps (with a baby rattle some more than others) i was told this was a runner but not 100%
how much is too much ?
has anyone got info on bottom ends ?
There's an actual specified end float value I reckon, if you have a Haynes or Gregorys manual it will tell you.
I'll check this weekend for you though
Edited by philbey
Undo the big end caps and check the jounals and bearing shells for wear. If good you can retorque them. Better still plastigage them.
As stated a bit of end play is normal, measure it with a feeler gauge. You should not be able to detect side to side play.
Edited by Felix
