demuire Posted May 26, 2005 Report Posted May 26, 2005 Umm... Trouble finding 2 things (in the car): - control unit - set/resume switch I took the whole interior apart, discovered the engine computer (above the "tranny tunnel"), but can't find the cruise control one. Also, can't find the set/resume swtich. I know the main switch is under center aircond vent, but where's the other switch? Quote
mikeys toy[RL] Posted May 26, 2005 Report Posted May 26, 2005 somewhere on or around the steering wheel, or turn signal stalk....maybe look behind the steering wheel Quote
demuire Posted May 26, 2005 Author Report Posted May 26, 2005 Yup, discovered it is part of the window washer switch thing. Now I just need to find the control unit... Quote
mikeys toy[RL] Posted May 26, 2005 Report Posted May 26, 2005 engine compartment; follow the cable from the throttle body back to the control unit Quote
demuire Posted May 27, 2005 Author Report Posted May 27, 2005 No no, that's the actuator. I have the actuator. I need the computer thing that controls it... Quote
Medicine_Man Posted May 27, 2005 Report Posted May 27, 2005 My cruise control always works, its called my right foot :) Quote
demuire Posted May 27, 2005 Author Report Posted May 27, 2005 Found it. For anyone who's wondering, it's behind the fan blower on the passenger side, tucked away where you can't see it and can't reach it. And if anyone's interested, the central locking module is above the glovebox. Taking out either of these modules requires the entire dash to come out. Umm, just out of interest (maybe Teddy would know or have access to knowledge?) my Camry has some of the plugs required for the cruise control. Namely, there are plugs to plug the cruise control main switch in, there are plugs to plug the actuator and vacuum solenoids in. But there are no plugs for the control unit or the brake switch. Any idea where the wires from the plugs that are there go? It's almost as if Toyota started putting the cruise control wiring in, and then halfway through decided not to finish it... Oh, also the set/resume switch is on the window washer stalk, and they appear to be interchangeable. Haven't checked if the body loom has the required wires yet though. I'm probably going to end up custom wiring the entire thing, but if there is already existing wiring to tap into it would make life a lot easier. Quote
