Carby Help
Took off stock carby, including polution gear, tried to put on webber, that fell through and now i just need to get it running again for work commitments.
Now the car wont idle, and wont maintain revs and just drops in rpm
Put the stock carby on, don't know which line is the vacuum hose line, tried all of the pipes, with every open line blocked up in one form or another.
Just take it to a mechanics and get them to fix it up or is it only simple and easy?
Did you connect the plug that comes off the carby? it should have a green end. if its not plugged in the car wont idle
thankyou man, that was it -_-, what is it, fuel solenoid????? carby solenoid or something, does it do anything besides maintain idle?
how i wish i knew more about carby's
and that is all that needs to be known about it :P
