my alternator is charging a bit low under full load, ive read somewere i can swap the insides out with a ford xe 90amp alternator?
can anyone confirm this?
and pick a part is having a special $15 alternators this weekend
win win :D
Most Bosch alternators are very similar internally, Take some measurements and see how you go. You will have to use the same rotor and stator/rectifier out of the bigger unit.
I converted mine with what I believe is camry internals just from bits off the shelf at work and it peaks at 100A fully loaded..
Only way to know for sure is to have a look and find out if the bits will interchange, I ended up needing a spacer on the pivot mount when I was done because the alternator stator is wider than the factory 45A bit of gear.
