June 1, 200521 yr comment_47134 I'm not sure if anyone has posted this up before (is this the link Doug posted up ages ago?), but came across this: Tech Edge Report
June 4, 200521 yr comment_47633 yup, thats the one. i use the fuel mixture display kit in standard narrow band mode. still is an awesome tuning aid for NA carbed engines. wouldn't worry to much about a wideband setup unless you have a hot turbo setup and a programmable computer. Report
June 4, 200521 yr comment_47713 they say the jaycar kit is designed for a certain sensor, but will work with other sensors if you "calibrate it". not having an AFR meter or a dyno shop or an efi car to do this with, is the difference really that great? Report
June 5, 200521 yr Author comment_47859 Another kit I've got a Jaycar one, but the one that uses LED's (instead of the readout). I have absolutely no idea how accurate/inaccurate mine is, I suspect the latter is more correct. Report
July 15, 200521 yr Author comment_58140 If anyone is interested, John at ImportBitz sells the Innovate Motorsports LM-1 kit for $595. http://www.importbitz.com/electronicnew.htm Report
