parrot Posted August 10, 2009 Report Share Posted August 10, 2009 No! Only use this technique on a car at the wreckers, or if you are going to change the seal on your own car and want to protect your own trims. Quote Link to comment Share on other sites More sharing options...
JiP Posted August 10, 2009 Report Share Posted August 10, 2009 That strip along the side of the car as far as I know is a generic strip and is available aftermarket brand new. Quote Link to comment Share on other sites More sharing options...
JOEKA Posted August 14, 2009 Author Report Share Posted August 14, 2009 From? Quote Link to comment Share on other sites More sharing options...
JiP Posted August 15, 2009 Report Share Posted August 15, 2009 I'm not entirely sure. Try rarespares, Clark Rubber, maybe even Repco or Autobarn. Quote Link to comment Share on other sites More sharing options...
Timaay Posted August 17, 2009 Report Share Posted August 17, 2009 (edited) I have used 10mm full chrome body mould strips. The hardest part was fitting them into the old hard seal but they now look a million bucks! Got them from supercrap. Also did the gutter strips in it too! Pull out old strips. Clean all openings of dirt etc. Cut to estimate length/size(makes it easier to play with) Remove sticky film Poke it in gently. Yes it may be hard with out damaging it. :P Next hard part is putting the original corner bits in. hahaha goodluck! Supercrap also stock those generic body strips. 15mm thk black with chrome edging. Also comes with the chrome tips for the ends. Edited August 17, 2009 by Timaay Quote Link to comment Share on other sites More sharing options...
JOEKA Posted August 17, 2009 Author Report Share Posted August 17, 2009 nicceeeeee, lol...thanks for that. Quote Link to comment Share on other sites More sharing options...
