  • Replies 41
far out i completely forgot about this,
reading it has got me all keen to lower the little ke again..
i have been doing a bit of research and asking around at the local auto shops, like was mentioned before seems anything pre ke20 doesn't have a listing.
i am definatley not going down the cut spring / no spring track... been there before with other old school mazda's and rolla's they handel like shit and its just dodgey.
at this stage i think I'm going to run a 2 inch lowering block in the back. and get some custom coilover sleaves and springs for the front and make them up.
..tempted just to do philbey's / scott's mod as i have a set of ke20 top hats lying around... and inch lower at the front may be enough? :jamie:
Do it, it's a piece of piss. Simple as.
Incidentally, I notice that lowering blocks are actually legal in south australia! I just happened to read it when looking through the DTEI information page the other day, but you still need the minimum heights etc.
yep i reckon i will, see how it sits with the ke20 hats in there.. i found them today in the shed... get a set of spacers made up this week, then ill have somthing to do next weekend!! :) good times!
Henry,
My ke11 had a double traverse leaf spring at the front.
Check out if yours does because I found removing the second leaf and running it
on just one, doing the ke20 strut to conversion and cutting 1 coil got my ride height
sweet and still handelled quite well.
I also had whiteline swaybar to compensate which is a MUST.
That being said I think you should go the coilover sleaves... let us know how it goes.
Scott.
Double transverse leaf you reckon scotty? What do you mean, like two of the top long leaf, or is it actually just two springs total? I never really looked, just assumed it was a complete pack in there.
Did you cut a coil off a stock KE10 spring as well, or off a ke20 spring?
Done. Just found them. Pale ale mate all the way.
when you at the pizza shop next, let me know, I'll come past.
thats awsome philbey!!, I'm in there on thurs night!!
cheers for all the info scotty, ill have a suss and let you know how i go! :)
Edited by kE20ME
I've found my ke10's have had just one thick single leaf at the front and my ke11's have had 2 leafs
in a pack.
I seperated the 2 leaf pack and used the main leaf from that pack.
when I compared this leaf with the single style from my ke10's it wasnt as thick so it allowed
the front to sit lower.
I just cut the one coil off the standard ke10 springs. The best way to do that is to wind the coil
off the bottom spring perch and cut a little at a time.
It'd be best to get a swaybar and do all these mods at once. Also remmeber to only tighten
the swaybar bushes up once you've got the car at the right ride height.
Make sense??
Scott.
took one strut out last night, some of those bolts were a bitch to undo!
looks like i only have one leaf at the front.. :)
my strut inserts are long gone though.. probably need to replace them i reckon.. what do people run? majordad in the thread said rx7 ones fit..?
might call around and bit today and see what i can find out.
I've got a pair of clapped out Koni's from a 911 that look suspiciously like they'll fit. A new set of Bilstein Sports to replace said item will set you back 300 bucks from the states.
Bring your strut to work tonight if you can and we'll do a comparison.
TP.
Give it a crack Tommy! its a bit of a bastard cause you gotta remove the LCA's
on at least 1 side.
hmm. only one leaf on your henry? wonder what models get one and what get two??
Its possible that if you can source a single leaf from the 2 leaf pack it will
still give the desired effect. might have a spare for you.
ke30 shocks fit with a spacer.
Worth looking into the rx7 option, probably be a shorter stroke.
