gryffinwings Posted August 18, 2009 Report Share Posted August 18, 2009 I have an AE86 GT-s Gauge cluster that I will be putting in my 1980 Toyota Corolla Liftback with a 3TC and T50 tranny, the stock gauge cluster also has a tachometer. Just doing the change because of the rev limit and speedo is higher. I need the color coding of the 1980 TE72 Corolla Liftback Gauge Cluster wiring and I need the AE86 GT-s wring confirmed, here's the AE86 GT-S Gauge Cluster wiring color coding that I have, just need to make sure that it's correct: White Plug: Black/Brown = Tachometer wire (goes to ignition coil) White/Black = High Beam Indicator - Blue/White = Speed Sensor + Tan/Black spot = Speed Sensor - Red/Green = Door Indicator + Red/White = Door Indicator - Red = Seat Belt Light Yellow/Blue = Fuel Light Yellow/Red = Fuel Meter Tan/Black spot = Ground Green/Black = Left Signal Green/Yellow = Right Signal Blue Plug: Black/Brown = Dash lighting ground Green/Brown = Dash lighting Yellow/Green = Water temp meter Red/Blue = Power source Red/Black = E-Brake Light White/Green = Check engine light Second section of blue plug Yellow/Black = Oil Pressure Black/Orange = Charge Indicator + Yellow = Charge Indicator - Red/Green = High Beams indicator + Quote Link to comment Share on other sites More sharing options...
parrot Posted August 19, 2009 Report Share Posted August 19, 2009 I'm not sure if i have directed you to this link before, but the full USDM electrical wiring diagrams are here, which will at least enable you to check the GTS wiring. http://www.aeu86.org/index/technical-ae86-...at/9/topic=5158 Quote Link to comment Share on other sites More sharing options...
gryffinwings Posted August 19, 2009 Author Report Share Posted August 19, 2009 Nope you haven't but this will help for sure, thanks. All I need help with now is the TE72, here's a copy of what I got from somebody: Quote Link to comment Share on other sites More sharing options...
