Everything posted by gryffinwings
Project: 1980 Te72 Liftback
Well here's the block all painted and fresh from the machine shop and the pretty shiny crank fresh from the machine shop.
Holley 5210
I'm looking for diagrams and information on my Holley 5210 that I'm going to install on my 3TC, I need to know what the vacuum ports are and which is the fuel in and fuel return. I already know this is a water choke variant.
Gauge Cluster Wiring Color Coding?
Nope you haven't but this will help for sure, thanks. All I need help with now is the TE72, here's a copy of what I got from somebody:
I have an AE86 GT-s Gauge cluster that I will be putting in my 1980 Toyota Corolla Liftback with a 3TC and T50 tranny, the stock gauge cluster also has a tachometer. Just doing the change because of the rev limit and speedo is higher. I need the color coding of the 1980 TE72 Corolla Liftback Gauge Cluster wiring and I need the AE86 GT-s wring confirmed, here's the AE86 GT-S Gauge Cluster wiring color coding that I have, just need to make sure that it's correct: White Plug: Black/Brown = Tachometer wire (goes to ignition coil) White/Black = High Beam Indicator - Blue/White = Speed Sensor + Tan/Black spot = Speed Sensor - Red/Green = Door Indicator + Red/White = Door Indicator - Red = Seat Belt Light Yellow/Blue = Fuel Light Yellow/Red = Fuel Meter Tan/Black spot = Ground Green/Black = Left Signal Green/Yellow = Right Signal Blue Plug: Black/Brown = Dash lighting ground Green/Brown = Dash lighting Yellow/Green = Water temp meter Red/Blue = Power source Red/Black = E-Brake Light White/Green = Check engine light Second section of blue plug Yellow/Black = Oil Pressure Black/Orange = Charge Indicator + Yellow = Charge Indicator - Red/Green = High Beams indicator +
More pictures, short block completely disassembled, except for some bearings. Will be soaking some of the parts in Rotella oil to start cleaning them.
Making some good progress with the engine so far, head is off, found out that the EGR ports won't come off so I'm going to get them welded shut instead. Pushrods are good, lifters are actually surprisingly in good shape, so I will reuse them, I'll post pictures of those parts when I clean them up a bit. The only main issues I see are the valve cover and oil pan gaskets are really sticky, other than that everything is in good shape, I think I may change plans and just put new piston rings on, maybe new bearings, and milling the head and block a little to bump up compression instead of using the pistons I have, which I will probably use in a later build or sell. Anyways hear are pictures of the short block. Looks like the carbon build up indicates maybe to much fuel, so I'll have to clean those up when I pull out the rotating assembly when I get the short block hot tanked.
Here are the pics with the engine out: Empty and dirty engine bay Pics of the engine after some cleaning and it's still dirty: Basically, I've got a lot of cleaning to do, and I have things to block off on the block it looks like, if anyone can point out some things that can be blocked off other than the obvious stuff like the: 1. Fuel pump for electric one 2. EGR ports below exhaust ports 3. The emission piece on the top left on the front of the engine.
More disassembly: Old Carb and Dizzy out: Intake Manifold out: Intake, Carb, Dizzy:
Parts that have come in: Topline OE Conrods: More parts, Ground Control 7.1k, T3 Advanced Strut Tube Spacer, KYB AGX, MSD 6A :)
And the dismantling continues Condenser is out ] Air Injection Pump is out: AC Compressor is out: Starting get more progress done: AC Compressor on the left, AIR Injection pump on the right More AC crap: Left over Pulleys:
So I've started tearing apart my 1980 Corolla, so far it's going pretty good, not too much rust, but I do need replacement parts, the front valance that goes behind the bumper need replacing, since mine is bent out of shape. Anyways here's are pictures of what I've done so far. Headlights, Grille, and Turn Signal lights removed Bumper cover removed What's left of my Battery shelf Front Bumper completely removed Radiator removed, still had brown crap in it even after trying to flush it. How she stands now.
Back Fire? Please Help
Ok, so I definitely know that I have a backfiring issue, going through my exhaust. Now, all I know is these issues, this is on a 3-TC motor with stock carb. Car Idles at roughly 1000-1100 RPMs Car seems to run rich Back fire happens backing off the throttle Help is appreciated in figure out what my problem is. I've changed these parts: New NGK Plugs New Wireset New Distributer Cap New Distributer Rotor MSD Blaster 2 Coil Header back exhaust installed I'm thinking it's just that my car news a carburetor adjustment and/or timing adjusted, but I'm not sure right now. Thanks for any help.
Yeah, well I needed something to replace the shot suspension, at the moment I'm not sure what I should use up front, the Excel-G inserts are the GR-2 equivalent, actually they are the same line from KYB, from what I saw on a website. Anyways I've been having trouble finding much else, that doesn't take a while to get, I wouldn't mind getting Tokico shocks, but I'm not sure the best place to get them is. Anyways, I'm in the San Diego area. Anyways thanks for the welcome :(
Well Here's my car again, with mod list and all. Manufacture: Toyota Model: Corolla Model Year: 1980 Chassis Code: TE72 Engine Code: 3T-C Engine Displacement: 1770cc Transmission Code: T50 Body Type: 3-Door Body Style: Liftback Current Modifications: Interior: --Grant GT Steering Wheel Exterior: --None Engine/Exhaust: --Doug Thorley 4-2-1 Headers --Custom 2.25” Cat and Back Exhaust --Magnaflow Catalytic Converter --Magnaflow Muffler Suspension: --Front – KYB Excel-G Inserts --Rear – KYB GR-2 Shocks --Front and Rear Spicer Springs --Front Moog Endlinks Wheels: --14” x 6” Speedlite (?) Wheels Tires: --BFGoodrich Traction T/A HR 195/60R14 Parts to Order: --Camshaft Bearings --Main Bearings --Conrod Bearings --ARP Main Stud --ARP Rod Bolts --Valve Lifters --Hardened Pushrods --Toga High Volumn Oil Pump --Water Pump --New Radiator --Carter 4070 Fuel pump --Mechanical Fuel Pump block off plate --Engine Gasket Kit --Cometic Head Gasket --EGR Plugs --Valve Springs --BRD exhaust port plugs Parts on Hand: --3TC Head --Two Weber DCOE 45 --PJ Intake Manifold --Baseline Gauge Cluster --Rear Taillights --AE86 Front Strut Assemblies --AE86 Front Brakes --3T-C Valve Cover --Rare Parts Strut Rod Bushings --TE72 Complete Front Stock Brake Set --AE86 OEM Springs --Felpro Valve Cover Gasket Kit --Sachs Clutch Kit --Prothane Rear Bush Set with Upper Links (courtesy of Aikane) --Spare Distributer --2 Corbeau Forza seats --Front Hawk HPS brake pads --Isky Racing Cam TH-77 --AE86 GT-S gauge cluster --Ground Control Coilovers (400 lb springs) --KYB AGX short stroke shocks --TRD AE86 Rear Lowering Springs (Tentative) --Advanced Strut Spacer --Corner Signal Lights --TRD Badge --Topline OE Style Conrods --ARP Head stud kit --Toyota High Compression +1.5mm overbore pistons --2 x Corbeau Forza Bucket seats Parts on the way: --none Planned Modifications: Interior: --AE86 GT-S gauge cluster swap --Interior Striped --Rust Removal --Autogage Tachometer --Autogage Voltmeter/Oil Pressure Set --Point Roll Cage --Corbeau Forza Seats and slide rails Exterior: --Rear Wing (Style TBD) --Front Lip Engine/Exhaust: --Weber DCOE 45 --Dual Sidedraft Intake Manifold --EGR Removal and AIR Pump removal --Electric Fuel Pump conversion. --A/C removal Suspension: --Front – Front MR-2 KYB AGX Strut Inserts --Rear – Rear Camaro KYB AGX Shocks --Front Addco Sway Bar --Rear Addco Sway Bar Other pictures: --Doug Thorley 4-2-1 Headers --Moog Strut Mounts --KYB Excel-G Strut inserts --KYB GR-2 Shocks --Weber DCOE 45 (152)
