Urgent Fuel Pump Help
hey all i have a vl turbo fuel pump (genuine item)
and it has paddle terminals, i need to know ASAP if the larger terminal is the negative or positive, can't see any markings on the pump itself and please don't post unless your 100% sure as i don't want my car to catch fire ;)
I'm trying to get my car running by this arvo,
cheers
well it should have markings at the base of the terminals
90% sure the lager terminal is the postive,
just change the terminals around and disconnect the fuel line? fuel pump is buzzing and no fuel coming out, swap the terminals
nothing will catch fire and you see for sure witch way the fuel is flowing
i know it should but it doesn't, I'm not completely retarded ;) just a lil
thanks evan g, you are right.
pumps quite fast ;)
all worked out now :D
woo ;)
