Ae71 Tacho/speedo Dramas
Hey Guys, in relation to "slab" in rollaclub rides (AE71 with 2TGTE); How do I get the tacho to work? (+ or - wire from coil I am guessing, but soldered to which pin in the guages multi connector?). Also, speedo works, but trip meter and odo don't, sounds like a stuffed speedo cluster?
Tacho signal comes off the negative side of the coil.
http://www.rollaclub.com/faq/index.php?tit...Tacho_Into_KE70
And yes, Trip meter and Odometer gears may be cactus inside, just swap the speedo unit out of an ke70 / ae71 cluster to fix it..
